Symptoms on early 90's Force 50:
Engine cold; engine starts, usually first crank, and runs to full throttle OK.
After running at mid-hi power for 30 minutes or so, I shutoff engine.
Wait 5 to 10 minutes and engine is 'hard to start'. Finally after a few attempts engine starts to idle 800 rpm and seems OK. When throttle is advanced, RPM rises to ~ 1200 rpm and then engine immediately and abruptly dies. Scenario happens repeatedly. Occasionally I get engine to go past 1200 rpm and it runs fine until shutoff then restart is attempted.
Have replaced most ignition system components and Carb has been rebuilt by 'professional'.
Is this a fuel pump problem?
