Force 50 HP 1991 Timing specifications
mc000
Hi,
im searching for my Force 50 HP 1991, Timing specifications(full retard, full advance in Degree). I have to adjust my Timing.
Thanks for any answer.
greetings
mc000
jerryjerry05
If you read the first 3 posts in this forum, you should find that info.
mc000
Thanks for that information, but im only found something about 75-150 Chrysler or Force motor. They describe something with 30 degree.
It didnt help a lot.
Maybee there is someone who has a Manual for my Motor. Model: 508E91C
legalfee
To set the timing remove the spark plugs and ground the wires, Disconnect the kill switch wire, Turn the ignition key to on, Connect a remote switch to the starter solenoid. Connect a timing light to the number one cylinder. Push the throttle to wide open. Timing should be 30 degrees. If not loosen the nut on the tower adjustment and turn it, Tighten the lock nut when set.
Jiggz
You set the static timing following the previous post except you do not need to disconnect the kill wire instead you need a jumper for the neutral switch. This will allow you to crank over the engine with the control lever in WOT position. And yes, it should be at 30 BTDC. If you have to do this by yourself, the remote starter is required. Otherwise, you can just have another person do the cranking over at the ignition switch. Remember, you do not want to run the engine so make sure plugs are removed and the plug wires grounded. This will prevent damaging your CD modules.
