skylerjshelton
- Oct 17, 2009
- 25
Hello I need help. I have a 1989 50 HP force outboard that i only have spark coming out of one coil. I switched the 2 coils. the other coil fires. so that rules out bad coil. my next guess was the cdi box. i changed cdi box with another one i had that i know was good. no change. so my next thought was the stator. i changed the brown/blue stripe wires with the brown/yellow stripe wires and still no change. so my next guess was the trigger. i switched the 2 sets of wires coming from the trigger and the other coil started firing. does this mean my trigger is bad?? i have another trigger that have solid color wires, hooked that up by cross referencing the color codes still no difference. i need help because i have a fishing tournament next weekend and really needs to be running by then. all help would be appreciated.
