Force 50 Prop Search
Bob La Londe
Does anyboduy beside Michigan Wheel make a prop for the Force 50 anymore? They MW props are thick and have a very square edge. The same diameter and pithc MW is slower than the beat up old prop I just pulled off.
roscoe
Re: Force 50 Prop Search
The TurningPoint Hustler prop sold here on iboats should work.<br />If you have an older Force with over prop exhaust, you may need a different thrust washer.<br />If you have a newer thru hub exhaust, the Hustler is a perfect match.
Bob La Londe
Its neither. On that little 50 the exhaust is behind the prop.
roscoe
What do you mean its neither?<br />It either comes out above the prop thru an exhaust snout, or it comes out thru the center hub portion of the prop, right?<br /><br />I think we are just using different terminology.<br /><br />You didn't say what year the motor is but if the exhaust comes out thru the prop (1995-1998), the Hustler will work for you. I am using one on my 1995 70 hp Force and it works as good as the original Merc prop. They are only $89. :)
Bob La Londe
1990 507F90C the exhaust comes out through a snout behind the prop.
