Im trying to remove the flywheel on my 88 force 50 to pull the power head and replace the exhaust gasket. I go the nut off the shaft and am using a bolt puller but it just doesn't want to budge. The center bolt is as tight as it can possibly go and i have even given it some lube and some good whacks with a hammer but not loosening. Wondering if there is any other nut or bolt to loosen or remove other than the big one on top, or any tricks or advice?? Thanks
