Force 50 water tube
tom kriz
After removing my lower unit to change the impeller the water tube dropped out at the same time. Now I am trying to reinstall I but am unable to line it up. The tube has 3 angle changes and I cannot feel it enter the water passage at the top of the lower unit. I assume it should feel tight when it is installed??? Help
jerryjerry05
Re: Force 50 water tube
They usually go in from the top.(I think)You might get lucky and find the hole.J
