It will be interesting to see how it works out for you. For most people that can get the boat on plane, throttle back and cruise on plane at reduced power, the fixed trim is "good enough". OTOH, like our boat, trimmed all the way down, will come on plane pretty fast and top out at about 4,200 rpm even at WOT. Trimming it up and getting it on the pad ventilates the prop and gets it up to peak horsepower and it gains 7 mph, just in trim.
IMO, the CMC power tilt and trim is worth the money if you're on a big lake and do a lot of running on plane. It not only adds the trim and tilt, it allows getting more of the lower unit out of the water further back from the stern where that water leaves the keel and rises to fill the void. If we trim it sensible we haven't had any problem with water pickup for the water pump. But it definitely adds performance that a fixed-trim motor won't achieve.
