Force 50hp 1989 timming place
mick97
Where is the timing screw located on a 89 50hp force? Does anyone have a picture? Icant seem to find it.its the one with a black hood cover if that helps.
tommarvin
Ensign
We have a 125hp with a CDI ignition are timing screw is at the top of the tower shaft close to the underside of fly wheel connected to the trigger.
fmt2bx
this is the picture of a 125hp but i think yours is the same. red arrow shows the timing screw. Screen Shot 2016-04-30 at 8.44.37 PM.jpg
Nordin
At the Force 50Hp you adjust the length of the rod that moves the timingplate.
It is similar to the attached pics of a 125Hp and the location is similar as well.
BUT you have to unscrew the screw that holds the rod to the timingtower and length or shorten the rod by turning the connector cw or ccw.
jerryjerry05
WHY????? are you adjusting the timing???
​Usually there is no need to tamper with the timing?
Unless you change the trigger the timing doesn't move???
jerryjerry05
After I posted I saw it was a continuance of another thread.
.You shouldn't break them up like this.
