Re: Force 50hp - doesn't restart
start with your battery connection and work from there. And by that I mean check all connections [ solenoid ,battery cable terminals, starter, ignition switch ,etc]you are losing power at one of the connections and your going to have to check things to find it, either with a test light ,or logic probe and you may be able to rig up a buzzer out of an old door buzzer from a car [its like a audible test light ,you can here it when you get power instead of having to have another person help you] hope this helps. MOPARMAN
