Force 50hp - no pee hole
Tuni
I have a Force 50hp 1993 ( ser# oe011553) which runs without a pee hole. I would feel more comfortable knowing the water pump is doing its job and have read some blogs about installing a water tube from the top of the motor. Is the white plug (picture attached) the one I take out and replace with an elbow?
roscoe
Yes.
Put a 90* brass elbow and a piece of flexible hose on there.
Route it down and to one side, drill hole in lower cowling and stick the hose through.
A little epoxy will hold it there.
jerryjerry05
The hole in the lower cowl, they sell rubber grommets at Home Depot.
Makes for a better look.
Tuni
Thanks all for your input. Brass elbow, tubing, and grommet. I can justify chump change to purchase this stuff and won't even have to ask the boss for permission.
