Force 50HP spark problems.
Egelundvej25
Have a Force 50HP 2cyl. That will not start (very weak spark). I have done some measurements:<br />Stator resistance:<br />Red & Red/white wire = 98,1 OHM<br />Blue & Blue/White wire = 400,5 OHM<br />Stator voltage at cranking:<br />Red & Red/white wire = 18 Volt AC<br />Blue & Blue/White wire = 8 Volt AC<br />Coil resistance:<br />Input from blackbox to negative = 0,3 OHM<br />Input from blackbox to spark plug = 952 OHM<br />Negative to spark plug = 952 OHM<br />The engine no is 0E007767<br />Can anyone please help and tell me if the above values are OK or not.
12Footer
Re: Force 50HP spark problems.
Resistance values from "the book".............<br />in OHMS<br /><br />Stator high speed; 90-140<br />stator low speed winding;6800-7600<br />Trigger; 700-1000<br />Primary ignition coil winding; .02-.04<br />Secondary ignition coil; 800-1100<br /><br />But, as long as you don't have an open across a coil winding, let's see what's wrong with it....<br /><br />Do a battery test. Then, pull an amp reading from the starter. The reason for this is to elliminate the possability that the starter is sapping all the ignition's available voltage durring cranking. A quick-n-dirty test, is to pull-start it,and see if you have a stronger spark.<br />If no improvement, try it again, but disconnect the brown lead on the terminal strip, port side of the engine. This is the kill circuit lead. With it disconnected, nothing is going to place the ignition to ground. If there is a problem with this wire,(a short to ground in the wire itself,ignition or em-kill switches, or connectors), you won't be able to shut the ignition down. So be ready on the fuel line. Or better yet, disconnect the fuel line, and give each carb 4 or 5 squirts from a spray bottle with mix in it.
Egelundvej25
I have tried to connect a separate battery for the ignition, so there is a battery for the starter and one for the ignition. It did not help.<br /><br />I will try the kill circuit lead. Thanks.
