Hi, My 70 hp Force starts fairly easy, but after running and sitting a while it has trouble restarting. Some times it won't restart and I get towed to my dock. Next day it starts fine. Also, the fuel pump bulb does not firm up, but has been that way for a couple seasons. When I unclick the fuel line connector it will pump up firm to the input side of the connector. Things I have done: replaced all fuel lines,fuel filter and bulb. Took fuel pump apart, appeared fine, no tears. Pulled fuel line out of tank. It had a little screen in the inside bottom of tube. It was clean. Put in new spark plugs. Added 10 oz.of Sea Foam to gas tank. Let it sit and then ran motor for quite a while. Used carb cleaner in carburetor. Added Stabil to fresh 5 gallons of gas and ran for some time. Any thoughts on this appreciated. Thanks!
