Force 70hp running issues
Ron1234
Hi i have a 70hp force that is running rough. It seems to have a intermittent miss and at around 3000rpm has a knocking noise coming from the reed valve area. I have replaced all plugs and leads and all cylinders have 120 psi compression. It vibrates heavily when on the water and struggles to make it max rpm. Help
jerryjerry05
Always include the year? serial# ?
Can of starting fluid.
Start motor and spray the SF around the intake side.
Base of the carb and around the fuel pump base etc.
If that makes a difference? smooths out, misses more, stalls.
Then it's sucking air someplace.
Check the fuel for water?
All plugs burning right?
VivaLaMigra
Ugh! Noise from "reed valve area" never a good thing; suspiciously close to the bottom end if you ask me. Hope I'm wrong for your sake.
