Re: Force 85 Coil problems
just last week I had the same problem, turns out it was the CD module which controls the spark, luckily the 85hp comes with a spare, the same ignition goes on the 125hp four cylinder, you need to follow the wire going from the center coil ( should be orange ) to the CD, un-hook it and plug in the spare ( should be red ). then follow the blue lines from the stator two of them splice together and the other one dead ends tie them together and give it a shot. My model is set up with quick connectors, yours may have a terninal strip were all the wires come together which makes it alot easyer.<br /><br />credit for the later part of this scenario goes to Rollie who just helped me figure it out.<br /><br />Thanks-Goodluck
