I know I need to get that head checked out, but as i was looking at the engine just now i see a hose laying disconnected below the carbs. I d9nt see an obvious place it goes. The first 2 pictures show the hose with a yellowish connector. The 3rd picture is where it is coming from. Any idea where that goes and what problem it would cause by not being connected?
Also, i feel dumb but I'm not sure where the idle air mix screws are. I don't see anything that looks like what I thought it would.
I'm 99% sure the loose end with the brass fitting was at one point screwed into the air intake cover (black housing in front of the 3 carburetors)
Remove the (6) bolts (2 per carb.) to remove the metal air-box & re-attach hose/fitting
The function for that was when the motor is tilted up and fuel would leak out into the air-box collect and slowly get sucked into intake.
I also noticed,;the fuel line to the bottom carburetor is not properly attached and in poor condition
I would start with replacing ALL fuel lines if they have been changed with the new fuel rated fuel lines!!
The are few variations of carburetors used on these engines, So the air/fuel mixture screw(s) (one per carburetor) can be at the top in the throat of the carburetor OR on the side near the top will be a screw like bolt with a spring around it.
In either scenario of location the set up is the same!!
Turn them clockwise all the way in GENTLY!! Till LIGHTLY seated, now back them out 1 1/2 turn out (make sure you all three carburetors the same settings)
Here's a section of the late Frank S. post
8. NOW we adjust the mixture on the carbs. Set all low speed needles to about 1 1/4 turns out from lightly seated. Do not force as this will damage either the needles or the seats.
8A. With the engine idling in neutral, turn each the needles in equally about 1/8 turn at a time. Give the engine a couple of seconds between each adjustment to stabilize. Adjust until the engine either "sags" or stalls. Note this setting.
8B. Now go the opposite direction. Adjust until the engine runs rough, burbles, or stalls. Note this setting.
8C. Set all needles to the average between the two settings: That is, for example, if it stalled at 3/4 turn out and burbled at 1 1/4 out then set all needles to 1 turn out.
8D. Readjust idle speed to 700-750 RPM.
9. Take the boat out on the water and do a "hole shot"--Full throttle acceleration from a stop. If the engine "sags" then recovers and picks-up it is too lean. Open the needles about 1/16 turn at a time until the engine accelerates with no hesitation.
If the engine sputters or coughs or burbles, then clears itself and accelerates, it is too rich. Close the needles about 1/16 turn at a time until the engine accelerates smoothly.
10. I can NOT stress this enough! NEVER set the low speed needles less that 1 turns out no matter how poor the idle or acceleration. To do so will run the engine too lean and detonation and melted pistons at or near full throttle operation will result.
