Force 85 Hp, -88, Impeller replace
lago
Hi<br />Wonder if it's rel. easy to replace the impeller on my Force 85Hp?<br />Greateful for tips and tricks!
my new fishmaster
Re: Force 85 Hp, -88, Impeller replace
Its not that hard I did my 96 75force. I removed all the bolts holding the lower case on. Under the zinc tab I found a couple. Then disconnect the shift linkage before pulling apart a bent one will mess every thing up. It should slide right off get a big rubber mallet to help everything out. Use loctight thread locker on all your marine nuts and bolts. Take your time get a manual you should have no problem. I should mention take a flashlight and look up the tube to see if your comes plastic cam thingy.
