Force 85 hp stator question
le_pok
I have a 1989 Force 85hp. It cranks but won't start. I have checked the impedence on the STATOR. There are 2 blue wires, 2 yellow wires and 2 green/yellow-stripe wires:<br /><br />between 1st blue and 1st yellow: 739 ohms<br />between 2nd blue and 2nd yellow: 741 ohms<br />between both green/yellow-stripe: 1.4 omhs.<br /><br />Is that normal or is there one coil burned? Is this the reason why it won't start. Please help...
lonewolf5347
Re: Force 85 hp stator question
the two green with a yellow stripe are going to the rectifier. the first solid yellow @ blue have to be check going to a cd unit. the solid two green going to the next cd unit.when reading ohms check the one that are going to the cd unit,should be more than 600 ohms on each.
MCCAS
hey lonewolf; take your choice stater, trigger, or c/d, you will a digatil VOM to check it, dont use a anolog meeter...
