Force 85 hp steam come out of the exhaust
windless
Does this mean I might have a blond head gasket , The compression is 120 psi in all 3 cyc, new spark plugs when I take them out ,hard to tell if there is water on them. looks like they have a bit of oil on them .100_5392.jpg100_5393.jpg100_5394.jpg100_5394.jpg
pnwboat
Re: Force 85 hp steam come out of the exhaust
Steam coming out of the exhaust is normal. The colder the air temperature, the more steam. Pictures are kind of blurry so it's hard to tell if there's water on them. Looks like the white porcelain around the center electrode is carboned up equally on all 3 plugs, so that's a sign that they're all firing. Typically if you're getting water in a cylinder, that cylinder's plug will look almost brand new. The porcelain part will be white.
windless
THANKS FOR HELP ME, PNWBOAT. About the porcelain around the electrode thats great to know . THANKS Windless
jerryjerry05
Is it overheating?
Test the temp sender and the buzzer.
Salt /fresh water? Profile/loction?
Running on the hose?
You'll see more smoke/steam on the hose.
