Force 88 125hp outboard prop needed
chandler
I'm having a hard time finding the right prop for a used boat I have. I have a 18.7ft bayliner capri cuddy with a 125hp force outboard. I need a prop and keep hearing mixed reviews online about what diameter and pitch I need and the prop finder here doesn't help. I want to find an inexpensive rebuilt also - any ideas.
walleyehed
Re: Force 88 125hp outboard prop needed
I'd suggest a Bayliner dealer...they may have some rebuilt props, or at least be able to point you in the direction you need to go..... :)
Ditto's on what walleyehed said. Plus they can<br />look up what it orig had
rickdb1boat
13-1/2 X 15 should be a good starting point. Michigan #071035 cupped
revertmastec
Try e-bay some good deals on props there. 15 or 17 pitch is good.
