Force 90 rises on it own
new2u_sd
OK fellas, I have a 1996 Bayliner Capri SF 1704 with a Force 90 outboard motor. It is equipped with the automatic tilt button on the throttle lever. Everything works great . . . until I am out in the water and I started gaining speed, then the motor slowly starts to rise out of the water. I am SOMETIMES able to accelerate very gradually and I don't have a problem, but if I try to gun it, the motor comes up automatically and I have to completely pull the throttle lever back before it will come down by pressing the automatic switch.
From what I know about hydraulics, it seems it may need more fluid, or at least be bled. It has a screw/bolt on the side, which I unscrewed slowly with the motor all the way up to avoid fluid squirting everywhere. (It did not.) As I slowly took the screw/bolt off, kinda milky fluid dripped out, at which point I put the screw/bolt back in place and tighten it up again. The color of the fluid obviously does not seem right. I will definitely replace that, but I am not sure if this is the cause of the "viagra-effect" my motor is having.
Also, I think I know how to drain the fluid, take the screw/bolt off and move the tilt up and down to get all the fluid out. But how do I get fluid in? I mean, the hold is on the side. Do I just fill it with whatever it will take in that position? Do I need to worry about air inside? There are no hoses to bleed. It is just like a hydraulic jack, although I did not see an air escape. Maybe I need to look further.
And another thing, the motor does not have an engine clip/pins, the kind that holds the motor down, usually about 9 or 10 inches long. Could this be my problem? I just don't see how that would be the problem because it would not allow the motor to trim at all.
I've rattled on long enough. I just wanted to get enough info out there. Obviously a "newbie" at this, so your help would be greatly appreciated.
Joe in San Diego.
roscoe
Re: Force 90 rises on it own
I think you will find the problem to be in the controls at the helm.
Loose or broken wires at the switch are making contact when the handle is pushed forward.
Jim13
I had about the same problem but mine would do it in the driveway also, if I left the battery connected.
My problem was a corroded switch at the helm.
new2u_sd
I'll try that. Getting into the control lever looks like it is one solid unit, so I am not sure how much I will be able to detect in there, but I will give it a try.
Thanks for the help.
