Force engine overheating
Erik218
I have an 89 50hp force. It started overheating on me. I replaced the impeller and thermostat. No luck. Took it to the dealer. They replaced water pump housing. Told me it was fixed. Took it out and it overheated at low idle. Ran fine wide open. Took it back to the dealer. They tore it down again. In their water tank it had no problems. Just to be sure, they took the head off and flushed everything and replaced head gasket. Sent me home. I took it out and it overheated at low idle. Any suggestions are greatly appreciated.
The Marine Doctor
Re: Force engine overheating
HI Erik...there are 2 different impellers that can be used on your engine. 1 has 6 blades the other has 12. One is high pressure the other is high volume.<br /><br />I suggest you get the 12 blade one and give it a try.<br /><br />TMD
Erik218
The original was a 6. I will try the 12 and see if it helps. Thanks
