I ran out of gas with my 1987 force engine. Ipumped the bowl in my fuel line which got me enough gas to get to safety. I was towed to a fuel stationand refueled. Now my engine restarted but raw fuel was coming out the exhaust. When I got home I found the following condition. The engine runs but if I pullout one of the top pulgs it stalls. I then removed all 4 spark plugs and cranked the engine over. There is a normal amount of gas in the top 2 cylinders but raw gas spray out in a huge amount from the bottom cylinder through the spark plug hole and little or no gas to cylinder #3. All 4 cylinders have spark and the bowl in both carb work. Anyone know what could be stuck open to cause lack of gas to #3 cyl and a flood of gas to #4 cylinder.Any help would be appreciated as repair shops are takling big bucks to look at it as they don't usually work on force and seem to be at an advantage. I am going to pull the cards off and lokk for something obvious but could use help. Thanks Ralph.
