Force L-Drive Low Power/Low Compression
dave1979
I've got a late '80s Bayliner Capri with a 2-stroke L-Drive I/O motor. I should have never bought the stupid thing, but I'm into it for $1200 and would like to at least get it running well so Ican sell it for what I bought it for. I don't want to dump it on someone else unless it works or they know what they're getting.
I've got compression as follows: (from top to bottom) 0,105,110, 65. How involved is the fix for this? Is there a test that I can do to see if it's the piston rings or the reed valves or something else? Also, any good places to get parts for this lemon?
Thanks...
thumpar
Re: Force L-Drive Low Power/Low Compression
Even with very very badly worn rings you should not get 0 unless your guage is just not measuring low enough. Is that piston even moving?
dave1979
The piston does move. I'm going to squirt some oil into the plug hole and see what happens...
steelespike
Ouch!I'm no expert but if you do it right your self your probably out another 5 or $600 bucks.
dave1979
Yeah, I pulled the upper carb and found two #$%#ing wood screws behind it that had been somehow dumped in there. Yay. That might explain the low compression in #1. Maybe the third screw made it through and beat the heck out of that piston. The front of that spark plug looked like someone had dropped it into their garbage disposal. In other news, #4 bumped up when I put oil in the bore, so it's likely a ring problem there.
Can pistons even be bought for this thing? I listed it for $1000 (a $200 loss) on Craigslist after I found the screws. It still runs and cruises at about 20-22mph on the lake, so maybe someone can make use of it.
Is there some sort of junkyard for these things where parts can be salvaged?
steelespike
Parts are out there I don't have a clue on where but one of the force guys may be along with info.Hopefully you can find someone looking for a project.
