Force L drive power head swap??
krobertson
OK I have a question? What other type of power head can you put on this L Drive? I know larger Force motors like the 120 and such will fit on the 85hp I have now. But can you put a different power head on this drive unit and make it work?
jerryjerry05
Re: Force L drive power head swap??
The crank is different on the L-drive compared to the outboard.
The basic block is the same.
Same pistons,rings, carbs etc.
Just the crank/driveshaft coupler is different.
