force L-Drive trim pump
curtisv
Replaced the reservoir with new old one was cracked.
Bolted all up. Connected hydrolic lines and tested.
Goes up and down no problem. Tank all shiny and new. Holds fluid.
Small leak at compression fitting.
Tightened a bit. Still leaks.
Bit more.... Threads gone. Stripped clean.
Now in need of new pump, but L-Drive parts obsolete.
Any advice on a replacement. Can't find anything that will say it will work.
120hp 1990 US MARINE L-Drive 120LD90B
Thanks in advance for the advice.
jerryjerry05
There's a few on E-bay right now, put in. " l-drive pump"or Google, marine salvage, outboard salvage.
curtisv
Thanks.
Found 1 here in Canada last week.
Holy $$$$!!!
Just waiting now.
