force lower unit leaking lube from the shift screw
synergy141
I have a 125hp force and there is gear lube leaking from the shift screw near the bottom of the lower unit casing . How can I stop this?
synergy141
Re: force lower unit leaking lube from the shift screw
I heard you we not supposed to tighten or loosen the shift screw , should I go and just tighten it anyway?
roscoe
You can tighten it.
Do not remove it.
Hopefully that will stop the leak.
jerryjerry05
Tighten then test it if you need to replace the seal.Then get the seal first!!!Any place that sells Merc stuff will have that or can get it.
When replacing it put the motor in neutral then remove the screw and replace as sonn as you can.
DO NOT MOVE ANYTHING!!!!!!! Don't touch the prop.Don't turn the motor over.Don't move the prop shaft.
It will mis-align the work and then it will cost$$$$ Jerry
Jack Daniels
Is there away to test to determine if anything is messed up after removign teh screw. How can you tell if its not working properly?
synergy141
your motor will not shift properly so it will be out of alignment and make funny noises
roscoe
Then it will likely go bang.
