Working on a 1996 50 hp 2cyl Mercury Force. It will start and run only at wide open throttle. It had no problems when last used and shut off, but next day this is what it did. 105 and 110 cylinder compression. Had the carb off and cleaned out. Trigger coil has been replaced but seems to have been good. Don't know if related but noticed the tach is not working. Any thought are appreciated.
