Re: Force (Mercury)
It's hard to say what the asking price should be, but I can tell you that I've looked around for used parts off the very motor you're talking about on ebay, and I'm fairly certain that with a little work, you could probably get as much out of the engine by parting it out as you could get by selling it used in running condition..
I saw a lower unit on ebay for $375.. The control box, if it works and is in good shape, is probably worth $100 or more.. I've seen cowls anywhere from $35-$100.. Mid sections (aka exhaust housing, mid leg, lower leg, etc) from $50-$100.. Motor mounting plates, about $75.. Starters, new around $100...working, but used?...probably $50, easy. Used heads were around $75, if they're good.. Power tilt/trim, provided it's working -- $350 or so.. And that's all kinda the "low hanging fruit" off the engine. If you started tearing down the smaller parts on the power head...shift levers, carb, ignition components, stuff like that, you could pretty easily pick up $20 here, $50 there, etc..
Start adding all that up and it seems to me that anybody with a socket set and an ebay account could probably could make enough back to buy a used, working motor in reasonable condition off craigslist or something...lol
It's a lot of work, though. Personally, I wouldn't give more than the *good* used lower unit alone would fetch...and that's NO MORE than $400, at the absolute most.
ETA -- Let's put it this way.. If were were closer (I'm in KY :-/ ) and I saw your blown motor listed on craigslist for, say $400, and I could get it for maybe $325 or $350, I'd *probably* buy it from you because I have a 1992 70HP Force and it would be worth it to me to have a donor in case something goes bad. If you came down to $300, I'd buy it for sure. Hope that helps.
