Hello all i am hoping i can get a quick response here. I am transplanting my 1985 85 hp force motor from one boat to the next. My question is what size bolts i should use to go through the bottom of the mounting bracket. The top has those washer and wing screws on the inside of the splash well. The holes in the new boat are in the same place as the motor needs. But they are smaller. So i didnt know if i was suppose to be using a smaller bolt. I was thinking this since they used a block on the inside to support the transom and used much bigger bolts. Is there a size that works better then others.?
