This is in regard to my jet boat with a 120HP Chrysler Force OB 2-cycle 4 cylinder engine.
I've cleaned both carbs several times and the spark is strong. Plug looks like it's washed clean all the time. Starting is problematic due to excessive compression in the bottom cylinder. Runs on three cylinders pretty well, considering. Is this a mechanical problem??
Or is it excessive oil injection in the bottom cylinder?
Could water be entering the bottom cylinder from the cooling jacket?
Help!
Chip
Help!
Chip
