force outboard motor lower unit shift problem
Frank Acampora
Re: force outboard motor lower unit shift problem
Depends upon the year! If it is earlier Force--nor Mercury lower unit, then the rod screws back in. It is much easier to drain the lower unit and remove the water pump mount plate. Then you can look down into the lower unit and see where to screw it in. Othewise you need to feel around and hope that the square block it screws into is in the correct position.
ronnie4444
thanks i will try that!
ronnie4444
thanks i will try that and it is a 96 force
ronnie4444
i got it to go in but it just spins???
Frank Acampora
That's because it is a Mercury lower unit. That one has a cam inside it and quite frankly, I don't remember how the rod goes in. If the bottom is splined, then you need to feel around for the splines in the cam as you push down. Perhaps someone who has rebuilt one recently will chime in.
ronnie4444
well thank you and hopefully i can get this problem fixxed!
