Force Outboard Motor Tilt/Trim
dcromer
Can a tilt/trim kit be installed on a Force 1988 85HP motor. Forgive me if this is a stupid questions but I just don't know anything about motors. I have this motor on a 15ft trihaul and want to add tilt/trim capabilities. I was wondering if it could be done with out spending an arm and a leg.
rickdb1boat
Re: Force Outboard Motor Tilt/Trim
dcromer <br />Aftermarket T&T kits can be added for around $400.00 from CMC. They can be found at Cabelas site or Overtons. These are good units.<br /><br /> Cabelas <br /><br />Overtons
karlp
To rickdb1boat<br /><br />I noted your reply about using the CMC trim and tilt. I want to add power trim to 1978 70HP Johnsons which clamp over the transom. If I use the CMC tilt do I remove the clamping and hinge parts from the Johnsons ? Thanks
