neilschaal
- Jul 4, 2003
- 8
1997 Force 75hp. Not that many hours, maybe a 100 or so. I have rebuilt the carb, new spark plugs, good compression, could it be the reed valves? I have them out for inspection and they have alot of gap. Probably 3 or 4 sheets of paper would fit in some areas. The problem is the the engine will not idle. If I choke it, it will run at idle, but as soon as I release the choke, it will start to die. Is it the reed valves? Or something else?
