force 150 fl
- Aug 22, 2003
- 46
Hello to all! Back again . Replace my fuel pumps and she still smokes . I did a second compression test and had 150 psi stright across . I rebuilt the engine with 30. over in all 5 cyl two years ago .Had all the boaring done by a boat machine shop . Is 150 a good compression with 30. over pistons ? I pull the intake covers and check the rings they snap back when pushed on but I notice some oil was getting past the compression rings on the bottoms of all the cyl .Is this normal or is it blow by ? The plugs are not fouling but does she smoke .Is their a way to just pull the head and check for ring clearance to cyl wall for out of round cyl? Thanks again for all your help ! Jim
