I'm hoping you guys can help!<br /><br />I have a 1990 Force '90 that has a rebuilt Lower Unit. It seems to shift OK.<br /><br />A week ago, the engine would not start although the choke engaged and I heard clicking.<br /><br />The mechanic told me that the motor was "in gear"<br />and that it would not start. He fixed it by somehow <br />starting the engine even though it was in gear and <br />started moving forward<br /><br />He told me not to stop the engine while it was in gear, but<br />if it happened again, I should disengage the throttle cables at the engine<br />and move the flywheel to try to get it into neutral. <br /><br />Well it happened again ( even though I thought I being careful)<br />and although I tried rocking the flywheel in both directions<br />( I can see the prop turn) while tring to shift, it won't get into neutral<br /><br />Does anyone have some better advice? <br /><br />I read somewhere here that there is a wire I can disconnect.<br />("interlock switch") so I can start the motor and then try to shift.
