Force Trigger Install - New Problems
markh28
Force 50, 1988 model 507Y8D
Through the use of a DVA meter and diagnostics I determined a bad trigger was causing me to have no spark on one cylinder. Replaced the trigger and now have good spark both cylinders. The problem is it seems that when the throttle is moved forward into gear, revved up, then back to neutral the idle is at a much faster RPM than before. Here is a breakdown of the problem:
1. I start the motor. Starts fine idles good nice and slow.
2. I throttle it up into gear and rev it up a little.
3. I move the throttle back to neutral, the lower unit goes into neutral but the rpms are still as high as they were when I revved it up.
4. I push back on the trigger lever, I feel it "give" or click, then the rpms go back to normal idle.
I have set the throttle rod according to the Force manual specifications. The trigger we put in is a brand new CDI trigger. Almost seems like its catching on the stator or something in there?
j1r11
Re: Force Trigger Install - New Problems
I have your exact engine. I had a similar issue, but i noticed i still had to slightly adjust my throttle linkage to get it to go away, even though it was a bit off from what "clymer manual" said to adjust to. Maybe adjust a hair each way and see if it helps?
markh28
I adjusted the throttle cable so it was pushing back with more pressure on the control tower shaft and that seemed to fix it.
