WINDJAMMER
- Nov 25, 2002
- 16
just got this boat and motor a 1991 70 hp force, when i started it got no water at pee hole. changed waterpump, impeller, and snaked out the pee hole. still no water coming out of it. also tested thermostat it was good. pulled plug in head and water shoots out when engine is running. installed water pressure gauge and at idle it reads 5 psi at w.o.t. it reads 10/11 psi. is this a good water pressure or do i have more problems?<br />thanks
