Force10 LowerUnit-1997
Edock10
Water in lower unit oil. Anyone have info on replacing lower unit seals. Have repair manual but would like opinions from someone who has replaced them. Should I attempt the job or leave to marine mechanic. Also, can water leak thru water pump housing, just changed the impeller and now notice the water, not much but emough to cloud the oil. Thanks
wilde1j
Re: Force10 LowerUnit-1997
Most motors require special tools. If you've never done it before, take it to a shop, then you'll have someone to holler at if it's not right.
