Re: Ford 302 oil leak
I changed mine on a 351, its all the same though. You need to pull the crank pulley, and balancer. Disconnect any brackets attached to the timming cover, on mine my alt. bolts to it, and drive out the old one. Since I did not remove my oil pan, and the seal is ment to be changed with the pan off. I placed the timming cover back on with all of the gaskets except the oil seal. then using a little downard force on the timming cover I got all of the bolts to go in. Once tight slide on the oil seal and using a piece of wood with the center drilled out drive the new one on. I will say this it is a pain in the butt to change with out dropping the pan. For a diagram any car or truck manual will have diagrams and torque specs.<br />Good luck.
