ScoobyDoodyDoo
- Jun 24, 2003
- 11
I am trying to bring back to life the engine in a neglected boat. The engine last turned over without a problem in 2002. In its last time out, I believe the boat took on some water and a lot of the engine came in contact with saltwater. It was flushed out and hosed down immediately after but was never used since then. <br />Looks like the alternator has seized for sure. When I try to hear if the engine will turn over, I can hear the relay click but the starter does nothing (I tried bridging the solenoid). That is about as much as I know to do. <br />How can I tell if the engine has seized before I spend the money on a new starter? Also, can I check for cracks in the block just by running water through the system and see if any leaks into the hull?<br />Any help would be appreciated.
