Lance Lloyd
- May 20, 2018
- 5
working on a 95 Larson 190 with a 5.8 ford carbureted motor. Rebuilt the Holley carb and reinstalled, prime the inline spin on fuel filter and it ran great for a few minutes and died..seems that fuel is not getting from the fuel tank to the fuel filter. I refilled the filter once again and again motor ran fine until the fuel in the filter was all used up and engine died again. The question I have is can a mechanical block mounted fuel pump be getting weak? It obviously is strong enough to get fuel from the spin on filter up to the motor, but doesn’t seem to have enough vacuum to get fuel all the way from the fuel tank up to the fuel filter housing. I removed the line from the tank up to the filter housing and easily blew air thru it with no restrictions. I also tried just removing the main line from the tank side and cranked the engine while thumb over the end of the hose and felt to suction from the fuel hose. This has me stumped and was just curious if I need to replace the fuel pump or look into other areas further. Any advice greatly appreciated as I’m trying to have the boat lake ready for this upcoming Memorial Day weekend.
Thanks,
Lance
Thanks,
Lance
