Ford Windstar Transmission problem
DaleT
Recently received a 1995 Ford Windstar(3.8L 4 speed trans.) for free. Vehicle is in great condition physically and the engine is very clean. The only problem is the transmission lacks reverse. All forward gears seem to work fine and the fluid is only mildly discolored nor does it have a burnt smell. I will most likely replace the entire unit. I was, however, curious if anyone here might have an insight as to any issues or possible fixes short of an entire trans swap.
TilliamWe
Banned
Re: Ford Windstar Transmission problem
do you have a hill you can park it on facing downslope?
Bob_VT
Common problem. Reverse and first are the first to go. If you can find a shop that will rebuild the transmission it is a faulty O ring that normally causes that problem. <br /><br />It normally happens above 80K. Sadly it requires a complete removal and disassembly to repair.
dolluper
It's possible shift valve is stuck or frozen in the valve body
Bob_VT
Try some Trans-X see if it helps.
DaleT
Thanks folks. I've heard a number of complaints about this trans and just wondered if there might be an easy fix. Again thank you.
DaleT
TW, no hills, unless you count gravel at the cement factories. But we got lakes and rivers,hmmm wonder if a windstar will float.
D
DJ
Guest
The trans. is NOT unique to Windstar.<br /><br />You can TRY to "condition it" with some snake oil.<br /><br />But, get that stuff out of there, if you get it to shift.
TilliamWe
Banned
DJ you saying that conditioner may solve the problem, but it's bad to keep it in the trans with the regular fluid for a long period of time? Didn't know that, thanks for the tip!
Dreamer1Q
I'm actually surprised the motor is fine. Those tend to go the way of your transmission as well.
