Foreign item in top end
SWBuechler
So, I'm spraying fogger in the engine through the spark plug hole and the little red tube (like the one on a can of WD40) goes "poof" into the hole. I've tried everything to retrieve it but cannot. So, my question is this; Do I need to? Will the heat of the engine eventually melt it and burn it up or do I need to take the thing apart and retrieve it?
Alumarine
This has come up before. I believe the consensus was it will just pass through and be fine.
Like swallowing a penny...
Bt Doctur
The next time :
if its a carb, spray it in the carb until the motor stalls
if its FI, use a remote tank with the mix.
Volphin
That plastic won't last long on startup. If you wanted to get creative, use thin aquarium tubing and a small piece of sticky chewing gum on the end. Even so, it would be like using one of those little coin operated claw machines to get the teddy bear. ;)
Ayuh,.... The bit's, 'n pieces will be flyin' out the exhaust in seconds of start up,...
gm280
The only thing you would be worried about is if you still want that little red plastic nozzle tip. Otherwise, its history on start up. JMHO!
Post #3 has the correct way to fog should you desire to. however for over 30 years with I/O's have never fogged one for winter.
64osby
Get the cylinder to TDC, cover about half the hole with a vacuum tube. It might draw it out.
