redneckboater
- Jul 11, 2008
- 43
Hi all,
I have a 1989 Force 125hp Outboard and im about to rebuild the engine for the second time.
On the first rebuild only one cylinder failed but I rerung and honed the other three cyclnders since I was in there. And here I am again 3 years later and a different two pistons failed in the same way as the one did the first time. The rings just pulled thru the top of the piston without damging the cylinder walls (minimal scuffing easily cleaned up with a hone). Almost like they get caught on the ports.
This motor gets run very hard in the summer used primarily for wakeboading and other water sports and very little just cruising. So my question is this will a forged piston be able to handle more stress and not fail like the cast ones? Or do I have another problem than just weak cast pistons?
Thanks for any advice!
