Forgot to drain gear case lube
scicca
I started to loosen up my lower unit without draining the gear case lube first. Quickly realized my mistake and tightened everything back up again. Lost some oil in the process. Plan is to drain the oil completely and fill it back up again. Could this have caused any damage to the drive?
thanks in advance.
I attached a picture which shows that the upper and lower are slightly off kilt. I wanted to center them again which I why I loosened it in the first place.
1984 Mercruiser Alpha 1 Sterndrive 140hp
