PensacolaJason
- Oct 23, 2011
- 176
We were out yesterday and moving quite well when all of a sudden after pushing it almost full throttle for a few minutes, which we rarely do, the motor stuttered and then stalled. We tried starting again immediately and it would crank but not turn over. After a few more minutes it turned over but sounded pretty bad, like it was missing, so we limped a few hundred yards back to the dock barely above idle. It was smoking more than normal and I could smell a little gas. I pulled the plugs today and they looked covered
in oil. Also, they were NGK's and this motor suggests Champion plugs. Might also add that the oil pump
has been disabled so I pre-mix now.
My question is do you guys think fouled plugs would cause this and do these plugs look like they might be the culprit? Are their any other tests or troubleshooting I should do?
The motor is a 1987 Evinrude 120 hp E120TXCUR
