Found out the hard way.
titaniumneck
Never ever ever do this, I found out too late. Ding dong, a true de de dee moment. Simple job trading out impeller on 1988 75hp Suzuki outboard. Well I screwed the pooch on this one. Yep, I pulled the shifter rod out. And for those who are not familiar with this particular motor, the dog pin pops right out and the bottom of shifter is nice and flatttttt. So pull the gears, prop rod, yep salt water sitting in for ever, are at least 28 years, sleeve stuck like chuck. Well I got it done. 30 minute job, 2 hours, yeaaa me.
ezmobee
I put one all back together once without the key in the impeller. :facepalm:
gm280
Everybody makes mistakes. Some are easier to fix then others. But they all teach us things we really didn't want or need to know. :eek:
GA_Boater
I'll admit it - I've never made a mistake. Well, not the same one twice. Usually! :rolleyes:
Hope the Zuki is ready to roll now, TN. It's been giving you fits.
Its not a mistake....its a valuable lesson
titaniumneck
Oh, this is a different Suzuki, I'm still waiting for Russia to send obsolete parts.
bryanzzz
Well we are big enough to own up to our mistakes, mine....owned boats for 40 years...while troubleshooting an engine problem, I hook up muffs, turn on water crank engine...troubleshoot....cut off engine..cut off water. troubleshoot for several more cycles...water on, engine on..water off, engine off....then, engine on but forgot water on...1 minute later I notice Yamaha not peeing. Troubleshooting stops, go to dealer buy new impeller, install new impeller....drink beer
99yam40
I saw a guy run a Boss 429 on a dyno and someone forgot to turn on the cooling water water,
ended with aluminum from the heads dripping out of the headers
