found something in lower unit??
Status
Not open for further replies.
34coupe
1993 crownline, merc 5.0L /alpha1 out-drive....removed lower unit this evening to replace impellor/water pump and as i was just lowering the unit i noticed a flat piece of steel with a rubber edge laying there!!??!! theres a part # on it "14348" does anyone have any idea what this could be?? i looked up in the outdrive and in lower unit to find somewhere this thing could of come from,but had no luck!!
Re: found something in lower unit??
Ayuh,... That's the remenents of the Shutters,... They live at the Top of the Y-pipe...
Lack of water Smoked 'em...
34coupe
thank you!!! so now what?? harmful if not replaced??
Ayuh,... It depends on the hull, backsplash, wave action, etc...
They keep any surge of Water, Out of your motor....
34coupe
thanks guys!! pulled the elbows off exhaust last night and there they sat(broke)!! im gonna try and find them today and replace em!!!
Browntailer
Need to replace the shutter in my 2005 Merc 3.0. 2 dealers told me that the engine runs warmer than normal without it, and I verified that (about 30-40 degrees). Anyway, does anyone know how / have an easy way to get the rubber boots/ sleeves off the the pipe? They are so thick and heavy/rigid that I cant even budge them even though I got the clamps off. Thanks for the help.
Status
