Found this rolling around my oil pan...
thejeep007
I have no clue where this could come from. Thanks in advance
Don S
Re: Found this rolling around my oil pan...
That is not an internal engine part, I can tell you that for sure. How it got there, who knows.
tpenfield
You had a Bic lighter and a kuniffuly pin in your oil pan :eek:
thejeep007
With these..
thejeep007
Well the Bic I can claim the pin had me stumped... The timing cover was off for a while it must of jumped in in the night thanks Don
thejeep007
Haha you guys are brutal.... Back to work thanks
tpenfield
One of those pins that are used on an engine hoist I suppose . . . (click image for larger view)
ajax5240
Sounds kind of like the "surgeon left a sponge" in the patient kind of story.
As for the other small chunks of metal, I'd venture a guess that you will find where they are missing from in the rest of your engine rebuild. I would guess that they are part of a piston based on the look of the cast metal.
Hoosmatroos
Looks like a pin that holds my bimini. Can remove it to lower the Bimini.
