Found water in the oil pan
theawalker
Just resently purchased a 1988 Bayliner capri bow rider, that has been sitting for 6 years. the engine does turn over, but found a freeze plug that was popped off and we were siphoning the oil throught the dipstick and got 1 gallon of water before the oil started coming through the hose. My question is " Is this going to be a major problem"?
sea wolf
Re: Found water in the oil pan
Cracked block & manifolds possible because previous owner didn't winterize?= major problem. How much do u have into it money wise? Could turn into a money pit. Sorry.
Ayuh,... Welcome Aboard,.... That would be one way of puttin' it....
Bamaman1
They sell used engines on EBayMotors.Com in the boat section. Also, see BoatTrader.com. There are a number of boat salvage yards that maybe could help you. Too bad you've got OMC, as parts are harder to come by.
That's your least expensive way out--if you can call it that.
